I may not be correct and this is only from what I've heard but I've been told that these motors shouldn't be bored out because they are sleved motors but if the cylinder sill has the factory cross hatching throughout the cylinder wall then I can just replace the rings. That's just from what I've heard and read so I'm not too sure. But BTW This is my first engine rebuild so I really appreciate the advice. Also this is for a 2005 saab 9-2x with the ej253, so it should be the same parts as the 2005 impreza. Can anyone tell me the oem part number for the rings?
Iron sleeved blocks, like found in the EJ engines, can most certainly be bored out (to an extent). Even Subaru makes .25mm and .5mm oversized pistons.
Here is the part number for the STD size...
At this website they're $135 per set. I assume you need 4 "sets" (I could be wrong).They're pretty dang expensive! 😬
You can definitely get away without touching the bore and just replacing the rings. But, in my experience, you get more life and performance if you at least hone it. It's not required if, like you stated, the bores don't have any visible wear (ie the crosshatch is visible throughout the entire bore).
Again, always doing a bore and hone, even if the bores look good,
is personal preference on my part. As long as your measurements are within spec you can absolutely do it without over boring and/or honing.
Anyway, considering the price of the OEM rings, it may be worthwhile getting aftermarket pistons and aftermarket rings. Specifically, Mahle makes them for our engines and they're a solid brand to use.
Here is an option..
Mahle STD size pistons (you will have to add a quantity of 4) :
Mahle STD size rings: (RockAuto is out of stock)
Or I suppose you could take a chance and see if the Mahle rings fit the used pistons you have. You could also try Hastings brand rings (RockAuto has them in stock), I've had good luck with them in the past.
Either way, good luck and let us know what you end up doing! I'm hoping you get it all figured out.
