1 - 2 of 2 Posts
16 limited, mine has 3 jets. I noticed the middle one alone is hardly piddling out fluid. I took off the cowl and inspected the plumbing. Everything is connected ok so I began disconnecting one line at a time to troubleshoot. The one that puddles I can barely breathe through it. The other two I cannot get a hard breath through. On each line there is valve in-line, that cannot be disconnected on both sides.
Are these filters? There is no power to them so the pump must be in the fluid tank below the battery.
Did I somehow get these gunked up and nothing wants to pass through?
Currently disassembled, input appreciated.
Discussion Starter #2
Well fixed it somehow. With everything off I tested the pressure and it blew fluid as expected. Assembled it gently and tested and wham-o. Snugged all clips, etc. and still works fine. There must have been a link somewhere? Maybe where the fluid line bends around the hood support and under the cowl? Works great.
1 - 2 of 2 Posts
