I know Subie owners like to see where they are going, so I thought I would post this up.
An employee at the shop I work in sells HID headlight kits. Now here's the kicker. They are plug and play lights. The bulb and ballast run AC and plug in series with the OE light harness. Made in Japan so they are not cheap knock offs. No splicing. No inline fuses. No large bulky ballast. No excess wires.
I installed these lights on my car inside 1 hour. And they made a huge difference. The fogs took 10 minutes. The low beams a little longer because of the tight space I now have in the engine compartment. The only modification I made was to cut a hole in the back of the lamp cover to allow the HID harness to come through.
See the pics. If you want to contact him, its an Austin area code and 5760134. He has different temperatures and all the kits are vehicle specific. Cost is low.:29:
He also suggested leaving a message if you get voicemail or send txt. He will ship.
