1 - 12 of 12 Posts
2012 Cypress Green 2.5i Premium CVT w/AWP & Moonroof
I haven't seen any recent posts on this so I'm hoping someone might have a solution. I've got my crossbars out right now so I can carry my kayak this summer, and of course when you pull the crossbars out to use them, it leaves a hole that was previously hidden when they they were tucked into the side rails. I know water will drain out of these holes, but I have trees in my driveway that will dump leaves and pine needles and acorns, etc. in these holes. Has anyone found a way to plug these holes and prevent crap from getting in them? Thanks!
2014 Outback Limited - 2.5 CVT - Graphite ---- 'Rehomed' 2012 Outback Limited - 2.5 CVT - Deep Indigo Pearl - Could be a Black Bumper Masonite car ---- "RIP" 2010 Outback - 2.5 CVT - Silver - So's m
Try the hardware store - Look for rubber chair leg caps. OR sink stoppers. If necessary they could be glued in with sealant.
Painters tape? pick your favorite color and knock your self out
2012, 2.5i, with hitch and rear bumper step pad, cargo mat
I have been searching around my house for items that may work. So far a pool noodle cut and cheese grated down to 1/4 bigger than proper size works well. (doesn't look all that pretty but stops the buzz from happening). Other ideas that I had but haven't tried were a squash ball,pill jar with pop off lid wrapped in tape, wooden plug might do the job as well. I was also thinking is Subaru threaded the opening then you might be able to screw in a abs plug. Just ideas here. If you try them and they work, let us know. If you have any other ideas, then post them here as well.
2013 Outback 2.5 Premium CVT
No they don't.....what they do use is called Bear Bond.....more like roofing membrane....very sticky and strong.... Duct tape:headslap: nice try:rolleyes:
Yup, use sheets of it when one of our club members kissed the wall with his GT3-Cup car. Out come the sheets and once it's on, it's on that's for sure!:gasp: And known as Bare-Bond panels
Deanski
Deanski
I should have used Bear Bond with my sarcasm.
Same issue here. Looking to get black rubber stoppers to plug them up. But in the short term, a cork from a balvenie whiskey bottle works quite well. Larger diameter cap part plugs the hole, while the cork section prevents it from falling down into the hole.
Tried different sized drain plugs with no luck. Then found 2 black neoprene hacky sacs. Fits snuggly and is removable. I will keep them in the glove box when not in use. Great way to stretch the legs too on a long trip.
1 - 12 of 12 Posts
