Popping and Clunking Noise
2795 4
Hello,
Sometimes when I accelerate from 0-20 and let off the accelerator my 2006 outback 2.5i automatic will make a series of 3 popping and clunking noises coming from the middle and rear end of the car. The noise is loud enough to where I am able to hear it clearly in the cabin and also feel it. I checked the rear axles and they seem fine. My only guess would be either the driveshaft or the diff. its also worth mentioning that the front passenger side has a reman axle on it and there is slight vibration during low speed (0-20) acceleration. the axle is a cardone axle. Any one else have this issue?
2005 OBXT Ltd Obsidian Black 5MT
Make sure the heat shield that is above the catalytic converter, but below the driveshaft, isn't hitting the driveshaft. I had a sound that would only occur during takeoff and I traced it back to the heat shield hitting the driveshaft.
I had apparently hit a snow bank and bent it just enough to where it hit only when the car accelerated. I pulled the heat shield out, no more sound.
But, yes, also check the bushings. Popping is more likely the bushings. The clunk and kind of grind was the heat shield.
