2014 Diesel with very low mileage and well housed and looked after... but not necessarily confined to Gen 4.
Issue: Suspected flaky computer issues.
Why raise it here? Of course, there is the hope that someone can help put a finger on the problem. However, I suspect flaky, common enough, computer issues. These may be misleading many owners to expensive "repairs" (i.e. leading them to fix things that are expensive to fix but do not really need fixing) while the owners/repairers remain none the wiser. That is, I also want to raise awareness. There is a real possibility this is an issue to which Subaru is turning a blind eye.
Symptoms: Simultaneous light indications of a fault, being amber engine light, amber brake warning light, flashing cruise control light. Also, the cruise control really cannot be activated. Happens shortly after starting but the cars runs OK. The symptoms disappeared after stopping but only after several restarts.
Curiosity: Only happened twice but did so in proximity to the same location, six months apart, without going anywhere nearby between the two occurrences). What the locations have in common is a power substation in between (suggesting electromagnetic wave interference is the issue ... i.e. the circumstances give it a low likelihood of it happening in the same location being mere coincidence). The first time it happened it prevented the car from starting a few times, after having driven it away from the site of origin, but not the second time.
Other possibility: May be the issue initiated by flattened battery some time before the initial event. The battery was removed, recharged and replaced. This should not initiate the issue, but it is a 'flaky' issue.
Other symptoms: On the second occasion roadside assistance (of which I am a member) was available. Roadside assistance read the computer code which indicated something to do with shaft location. Roadside assistance could not clear the error but said it was safe to drive but recommended getting the sensor replaced. Roadside assistance also said the sensor was a diagnostic tool rather than a safety issue. However, roadside assistance also the engine should not start with this fault. In addition, roadside assistant agreed that the flashing cruise control light is irrelevant to the 'issue' indicated by the code. Also, noticed occasional weak acceleration.
I cannot fault the help and advice of my roadside assistance given the situation as it presented itself. However, consideration of all the circumstances make it highly likely the computer diagnostics are flawed.
