1 - 11 of 11 Posts
2015 Subaru Outback 3.6R w/ES
Hi,
I have a 2015 3.6r Outback, and for the life of me I can't find the power steering fluid reservoir. The steering seems to be getting harder, but the warning light has not come on yet. So I wanted to check the level and cannot find any mention of it in the manual, and all I can find online refers to the previous ten 3.6r
thanks!
2012 OB , 2017 Impreza
This question comes up frequently. I am not sure about your 2015 3.6 but most newer vehicles have ELECTRIC power steering. There is no reservoir nor pump. The battery drives an electric motor on the steering-rack.
2019, Subaru Outback 2.5, Brown
I've got a 2019 Outback and this question has been on my mind for a year! Just registered for this forum and am so glad to find this answer. Thanks brucep.
19 Outback 2.5i Premium
However, if you search around you can likely find a mechanic who will charge you to flush and replace the power steering fluid system ;)
But don't forget, you STILL need blinker fluid on new cars. :sneaky:
Would that be the same mechanic who throws in the "chassis lube" for free with an oil change - but charges a premium if it's a 4WD pickup?
I have a 2017 Subaru outback 3.6T and was wondering the same thing. Now that I know that it is electric, that explains why I can’t find the reservoir! However, this doesn’t address the question of noticeably tighter more difficult steering. Any ideas?
2020 Outback Premier 2.5i
Stiff electric steering means you need to add juice to the ps motor. :D
OK, kidding aside, all stiff steering complaint investigations must start with tire pressure checks.
All complaints should reveal when it is a problem...
  • minor course corrections as you travel in a straight line
  • changing lanes
  • steering around a corner or when parking
  • only when outside temp is cold
  • only on Tuesdays
  • all of the above, etc.
2015 3.6R Limited w/ES
Likely normal. My 2015 3.6R has relatively tight steering compared with loaners I've had in recent years (Ascent and Crosstrek).
Thanks. Tire pressures are fine. Maybe it is because the weather is a little colder. My wife’s 2020 ascent has a much different feel. We just got it, and maybe it is just the difference that I’m noticing.
1 - 11 of 11 Posts
