2004 Subaru Outback 4-Cylinder 5-speed
First of all, hello everyone. I'm new here. I have a 2004 Subaru Outback 5-speed that I absolutely love.
I took it to the mechanic the other day. I popped the hood and the alternator belt had shredded. He replaced the alternator (which I replaced myself 5 years ago). He said that alternators typically last 3.5 years which seemed strange as I hadn't had to replace it from 2003-2012.
When I was backing up and leaving, there was a loud noise happening any time I turned the wheel. I went back and he came out to hear. He said, "Oh yeah, I heard that when I was working on it but I checked your fluid levels and the belt is fine.". I told him that it didn't ever make this sound before I brought it in. He repeated the same thing.
Should I be concerned about this? Other suby owners ever have power steering issues?
4, Gen 2 H6's: 2001 LLBean, 2002 LLBean, 2002 VDC, 2003 Plain...I love the H6's!
One of my 2002 H6's had an o-ring crack in the power steering hose at the inlet to the pump, which caused cavitation and resulted in a constant, loud whine from the PS pump. No other PS problems for me. Hopefully, someone else can chime in with an experience related to your subaru.
1994 Subaru SVX LSI, 2000 Subaru Outback Limited, 2004 Volvo S60R, 2015 Lexus RX350 (Wife's)
I had the same thing happen on my power steering pump making noise. I originally thought it might be simple as a O-ring being old and letting air in the system, a quick & cost effective way to try to fix the noise problem. Unfortunately, in my case, the noise persisted. I could not stand it, I bought a re manufactured power steering pump from Autozone with my Autozone reward points. There are 3 bolts that hold the power steering pump bracket. The bolt holding the power steering pump to the bracket could be rusted and be very difficult to loosen. Lucky for me, I knew a mechanic & lent me a Snap-On box end wrench that does not have a angle, but completely straight. The straight box end wrench gave me leverage to loosen the bolt that holds the power steering pump from the bracket. I loosened the bolt that holds the powering steering pump to the bracket while the powering steering pump bracket was still secured to the engine. Here is a video, I watched on Youtube to get an idea on how to replace the power steering pump. I don't know why this guy took off the upper radiator hose, totally unnecessary. Here is the video:
