I have a weird issue with my 2012 Outback. If I'm going highway speed (60+ mph) and put my driver side window down, when I go to put it back up, a lot of the time it will stop when it is 99.9% up (you can't see a crack anymore, but you can hear the airflow). If I try about 10 times in a row (roll down a bit, then back up), it will eventually go all the way and make a "shunk!" sound like it is being sucked into place by pressure.
Here's more evidence that pressure plays into it somehow. If I roll BOTH front windows down, whichever one I put up first goes up no problem. It is the SECOND one that will get stuck when almost closed. If I'm having problems closing the driver side window, I can crack the passenger side and then the driver side will close simply. But then I have problems closing the passenger side.
None of this is a problem at lower speeds or stopped.
Has anyone else heard of or experienced this problem? I may take it up with the dealer, but I imagine they will try to blame it on my window tinting. Thing is, this problem occurred even before I got them tinted. I've just been dealing with it for a while and ignoring it, but now I'm wondering if I should get it looked at sooner rather than later.
