2013 2.5 Limited
Quick question. I have the base premium head unit. A buddy purchased an aftermarket setup and I can get his hk non nav unit. Can I flip that unit in, even though I don't have a hk amp? Basically does the hk head unit have it's own power, or is it all from the amp?
Thanks guys!
You will need the amp. If you can talk him into wiring around the amp you could use it but you will need the harness from the car. For the money I would look into an aftermarket like he used.
If the speakers are anything like the stock speakers in the base model, change those out first. The speakers I pulled out of my car probably cost about $5.
2013 2.5 Limited
agreed, if it were plug and play i'd do it... with all that it would take to do it, aftermarket is the way to go for sure.
