Those only seem connected by the computer CAN bus but the dealer is likely the only one with the right tool. That laptop they use with software is about $5K/year.Any ideas?
Started my 2018 Limited 3.6R yesterday.
Many dash lights stayed lit, including Eyesight (and its dependent functions), check engine and the x-mode light is flashing. After further checking, the outside temperature indicator is blank, the heat only warms up at the highest setting, the front passenger window won't open (all others work fine) and the rear hatch won't open from any of the dash button, the hatch button, or the fob.
Otherwise the car is running and driving perfectly fine.
What in the world would cause this? Should I just head straight to the dealership?
You could reset everything by removing the battery terminal for several minutes to reboot all the bits and see if it is happier. You could also pull all the codes with a reader but those are different enough components, I am not sure what can be done without better tools/knowledge than a consumer would have access to.
