Wondered if anyone had seen this problem before. Its a 51plate outback with 2 section sunroof. The part over driver just tilts and rear section opens completely.
The sunroof had been working fine until last week when I tried to open it. The motor runs but the glass doesnt tilt. The rear section works fine. If you push the glass up it goes up but then just drops back down as if a gear has broken? When you close it the glas does lock correctly.
Any ideas?
Cheers
There are a couple threads on this. Part is replaceable, a hundo or two, but the entire front/rear mechanism gets removed as one piece, non-trivial.
This happened to mine, the front section locks down fine so I just shove a rubber doorstop in it to hold it open.
