1 - 20 of 22 Posts
I've read the fog light threads here and elsewhere until my eyes turned yellow, but haven't seen this side of the discussion: How can we put those OEM fog lights to good use if we don't have fog or snowstorms to worry about? We know the usual arguments against that:
• For show, they look juvenile.
• For seeing emerging deer sooner, they might help, but not above 20-25 mph.
• They look bright, and their range is severely limited, because they shine primarily on the pavement right in front of our noses.
• Installing brighter bulbs changes none of those all by itself.
• Only driving lights will reach waaayyyyy out there beyond our high beams, and only in a narrow beam (if legal).
• Aftermarket HID conversions are illegal in many states and turn most fog lights into obnoxious, glaring light bombs.
So if we don't need classic fog lights for heavy snow or fog and want to improve our view, in traffic where high beams and driving lights are not practical, beyond just swapping for more powerful bulbs, without bolting too much crap on our bumpers, without attracting cops or paying fines, without blinding others, making max use of existing or stealthy replacement hardware, ... what to do ... what to do?
Replacing the OEM fogs with little bitty round lights -- e.g., better fogs, driving lights, low projector beams -- presents a whole list of problems, from fitment to lighting patterns. Anyone who wants to fabricate a whole new mounting system for that quest needs a hobby ... that, or dweebing with his car IS his hobby. ;)
KISS; aim your existing OEM fog lights higher. HIGHER. MUCH higher! Oops ... that's too much; don't want to irritate everyone, or even just one policeman. Once we point them higher than normal so they aren't glaring off the pavement near our front bumper, their sharp top cutoff and extra beam width let us throw a lot of extra light onto the shoulders of two-lane rural highways and far enough ahead to do some good at highway speeds, and gives our low beams a boost down the road ahead.
"But how?", you ask. "Two ways", I answer.
1. Use the adjustment screw.
2. If that's not enough, tilt them in their mounts or tilt the mounts.
Mechanical details will follow, but first let's understand our objective: it is to raise the projected beam so it's just a little below horizontal. That way it cannot blind oncoming drivers on level roads, and we can't control hilly roads anyway.
We could use Stern's excellent beam aiming geometry tutorial at
Daniel Stern Lighting Consultancy and Supply , or we can use a yardstick, a wall, some masking tape, and some flat ground, plus subsequent fine tuning based on road testing. I favor the latter. Without getting mechanical yet, here's the general approach.
Park on reallyreally flat ground 20, 40, 50 -- whatever -- feet from some vertical target object such as a wall, a tree, another car, a big cardboard box in front of your vehicle. Measure the height of the center of your fog light lens above the ground. Mine's about 17" on my 4th Gen Outback. Place a piece of masking tape horizontally on your target at that height in front of the fog light you're re-aiming. Block your headlight beam with something so your fog light beam upper edge is distinct, and turn on the fogs. Then re-aim your fog light higher ... higher ... higher until its beam's sharp top edge is at, maybe up to a cm above, the masking tape mark. Repeat with the other fog light, then hit the road and make two tests:
1. Make sure your fog light beam's top edge is at or below your properly aimed OEM low beam's top edge at all distances. (That relationship will change with distance because the low and fog lamps are at different heights. I.e., the fog light beam will climb higher at greater distances if it is above horizontal.)
2. Pay attention to oncoming drivers. I don't mind one car out of a hundred flashing me, but 5% tells me they're high enough to blind others and attract cops.
OK, some mechanical details. With built-in OEM fogs, we have two adjustment options: the beam height adjustment screw and shimming. The adjustment screw will help but probably will not bring their beam up to horizontal. If that's your case, as it is on my 4th Gen OB, you'll need to find a way to shim the fog light assembly so it's tilted upwards a bit from stock. It takes only a fraction of a millimeter of shimming, so it's pretty simple. Let's dig one level deeper, using my OB for example.
Drop your plastic fender/splash liners to access your fog lights according to your owner’s manual or Googled instructions. With a flat and a Phillips screwdriver and one or two minutes, that fog light is now fully exposed. You’ll see its adjustment screw or thumbwheel. Turning it clockwise (it takes some effort) raises the beam, but not enough to raise it up to the masking tape you put on your cardboard box. You thus need to shim the assembly to tilt/point it upwards a bit.
How much? We’re trying to raise a beam by mere inches at tens of feet by shimming two mounting points two inches apart; our leverage is hundreds to one. We’re talking about the the thinnest washer we can find for a shim. A hundredth of an inch was enough for my vehicle. Piece o’ proverbial cake!
Now let’s dig one level deeper. The fog light canister has four mounting flanges/ears with holes in them. One is mounted via a single mounting bolt, one slips over a plastic locating stud, and two slip into plastic slots. All that becomes obvious as soon as you bend the splash guards down and look at the light canister. Remove the single bolt, wiggle the light assembly out of its “bed”, and get out your advanced shimming tools and materials: A thin washer that fits over that bolt, a file maybe a half-inch wide, and some duct tape. This is serious stuff!
We want to pull the top of the light back a hair. The washer does that for the bolt side, and the file does that for the plastic slot the other top ear fits into. You want to “move” that upper slot back a tiny amount by filing its back edge off a bit and adding a few wraps of duct tape to its front edge. Precision isn’t necessary; that’s what the adjustment screw is for. I also “moved” (filed) the lower mounting slot/surface forward a little bit so the light assembly isn’t stressed (I doubt that matters) when remounted.
HAH! Now my beam is above the masking tape target, as desired of my mechanical work. I can now bring the beam back down to the tape with the adjustment screw. Time for the road test. If that goes well, I’ll upgrade the bulb to a more efficient (i.e., brighter, but with OEM wattage) bulb.
I’ve also drilled a quarter-inch hole in the plastic liner/pan so I can reach the adjustment screw without even touching the vehicle next time.
Stay tuned. Road test coming soon.
I hope this is clear. I’m not going to bother proof-reading it unless somebody says HUH??? ;)
I've found that adjusting them so they cover more area to the side ie the passenger side has been great for outback roads and spotting/reading dark street signs. I haven't done this to my new OB. I did do it to my old 01. Which I hardly ever ran them unless I actually did need to see the side of the road or read a sign.
I just found out that my other fog light simply adjusted, via its OEM adjustment screw, plenty high enough ... well above horizontal. Saved me the hassle of shimming the light assembly. The first side had MUCH less adjustment range.
Mike
I did this adjustment on all my past Subs with great result. My 1998 Legacy GT had average head lights and the fog height adjustment made night driving safer. My 2004 Legacy special edition had the dual road/high beems bulb and was really not performing enough, the fog lights were powerfull although and did help a lot for road side visibility once adjusted. I just got my 2013 Outback wich has similar fog lights then my 2008 XT and I will get them adjusted this week in my garage. I found that my new Outback has the road light stay on when the high beams are on witch results in very good night vision but the adjusted fog will assist the road lights a lot once adjusted during normal driving. The fog lights are adjusted from the factory to their lowest position and my dealer has refused to adjust them on my 2004 Legacy... It's a nice DIY improvement at no cost.
I just put a 6K 55W HID conversion in my fogs, and a 35W conversion in the low beams, over the weekend. I didn't tweak the fogs higher yet because I wanted to see how they looked on the road. They definitely need to go higher, so that's the next step. Properly adjusting the lights up, without blinding oncoming drivers, is much more critical with the HID conversion. The low beams were fine with the factory adjustment.
Consider blocking off the lower half of the lenses to avoid putting too much glare out for other drivers. If you install HIDs without real projector lenses, it's the least you can do.
AnotherMike: It appears that some 80% of this nation (in many areas even more) look juvenile because they have them on all the time. Who will do anything about it? Is anyone capable of changing habits of an average American driver? I sincerely doubt it...LOL
One thing first : It does matter how far away you park your car away from the test wall. Go ahead and start at 20'away from the test wall. Mark your target spots, and then adjust your fogs accordingly. Back up to 50' and see what your fogs are illuminating. Bet it's a lot higher, and I bet I would flash you. It's the target that is the goal. How you go about it matters not.
Fog lights are intended to be just that. If you want DL's, install some. Then hope you don't get behind a cop. The other reason to have fogs (where I live anyway) is that there is a good law here that requires headlights on while raining. Duh. You are turning them on so that your gray car on a gray road with a gray sky can be seen. Not to see better, but so I can see YOU!!!
boxerfan67: Are you saying no current Lexus, BMW, Audi and some Benz cars cannot get behind the cop? What happens if they do, since all of them have LED DRLs...?
80% of drivers in my neck of the woods have fog lights on all the time - and they frequently get behind the cop ... and nothing happens....what exactly are you saying?
I cannot help but read this with the classic 60's TV super-hero announcer voice.
What voice would you assign to a statement (actually a fact) that some 80% of drivers in NW FL never use turn signals? I vote for Sasha Cohen's voice in Borat ...LOL
Are we discussing safety issues here or chewing fat on clichés...LOL
Just leave your hi-beams on all the time, it's cheaper and easier, you'll see plenty far and most people are too lazy to blink their hi-beams back at you anyway.
The crux of my message is why use fogs in clear weather (I believe that was the original thread)? Why use any lighting at all in clear weather? I cannot understand the concept of DRL's. If you cannot see me coming when the weather is nice without the aid of lights on my car, then I would think it's time to give up the keys. Also, on the flip side, The DL's you mentioned on the exotic end are calibrated not to blow out the person in front of you. Perhaps, as on my car, the fogs will only work on low beams, Merc's, BMW's etc. may be the same way...when the brights are on, that's ALL that's on. If people enjoy riding around in the daytime with their headlights and fogs too, more power to them. But to adjust an existing light to do something it was not intended for,(the concavity of my 02 OB reflectors are far wider than my headlights are) all that will be achieved is that now, looking directly at it is more blinding than before. I just don't see how it would help the driver see better unless the concavity of the reflector is reduced. Hope that helps.
Boxerfan67:
That helps... somehow... but I still don't understand why most people here in NW FL have fog lights on all the time? Any clues?
Also, not sure what do you mean by "calibrated" LED DRLs on those "expensive" models. The only "calibration" that I can think of is dimming....I don't see those DRL lights being dimmed or pointed down, etc., when one of those cars is behind me, do you?
They must have been DOT approved, so why worry about being behind a cop?
Boxerfan67:
It must be a local phenomenon. I'm probably not more than 300 mi. from you geographically, maybe a beach thing??? On to the "calibration" issue. The DL's more than likely have been aimed toward the right at a distance decided by the automaker. Also, My DRL's are not as bright as when I actively turn my headlights. Don't know if this is because less electricity is being sent to the bulb, or something else controls the brightness. Whatever it is, I sure would love to disable the DRL's completely.
Thanks... on 2013 the DRLs are actually dimmed high beams - no "loss of power"... that is the way, they are designed. It might be the same on your model - not sure though.
The reason I dwell on this is because I actually think that DRLs are a safety issue. Same as rear fog lights that I have just installed on my 2013 OB. That safety issue still did not filter into these woods... As you have mentioned, it's better and safer "to be seen" ... in many countries and many states they are now mandatory. All of Scandinavia, all Nordic Countries, all of Canada and most EU countries....there are many statistics that claim decrease in accidents....
I just find it disappointing that the average driver requires DRL's to operate a vehicle safely. I still hold that if someone is reliant on others using their headlights in the middle of a clear day to operate a vehicle more safely, then like I said, it's time to hand over the keys, or, as I KNOW, for Alabama anyway, the driving test is incredibly easy. If that's not bad enough, one is able to attempt the test UNLIMITED times. It's a huge responsibility every time one gets behind the steering wheel and starts her up, and now after finally passing the test on the 14th time; OFF WE GO!! Another scary issue here is that once issued a drivers license, you have it for life. Even the octogenarian who can barely read his mail can go hop in the big Caddy or whatever, and take a little ride.:confused:
I modified my lights a few years back as follows:
1) Philips Xtreme Vision H1 bulbs in the low beam housings. I was running their +30 and +50 ECE bulbs that I was buying from a store in England before the latest version became available from Candlepower.
2) 9005 high beam bulbs in place of the stock 9006 in the factory fog light housings.
3) Using the adjustment screw, I took the upper beam tails a little above the horizon for some long distance vision, and more side illumination.
4) Ditched the silly plastic grills.
5) Added a relay and secondary dash switch so that I can selectively control the fog lights to come on and off with the high beams.
Comments and results:
1) The low beams are brighter and whiter within the legal coverage area, with slightly better/sharper cutoff than the stock bulbs. I attribute this to tighter build tolerance and filament placement. Net is more useable light where you need it with less glare to oncoming traffic.
2) I NEVER use the fog lights unless I am driving in FOG or blowing snow (with low beams), or when totally alone on dark country roads when using the high beams. And even when using the modified fogs with the low beams, I will sometimes switch them off to not impact oncoming traffic.
3) Despite the higher aim and brighter bulbs (1700 lumens instead of 1000 lumens, for only 10 watts additional draw), they still retain reasonable ‘fog light’ capability. They produce improved distance vision in bad weather without reflected glare as they start out low enough, and it’s far better then blinding yourself using high beams.
4) The relay / switch solution gives the options of fogs always off, fogs on with low beams but not high beams (stock arrangement), fogs off with low beams but on with high beams, or fogs on with either low or high beams.
5) The relay output is wired directly to the harness a few inches from each fog light, rather than hooking into the underdash feed. I found that by avoiding the existing dash controls in the ‘on with high beams mode’ I get about 1 volt higher to the lamps. Apparently there is a bit of a voltage drop going thru the stock arrangement. As filament emission is somewhat logarithmic with voltage, the net is a surprising increase in brightness.
6) So far, no meltdowns with 65w rather than 55w fog draw (about 1 amp more per side).
7) MOST IMPORTANT to me – Total illumination with high beams for deer spotting is just amazing! To give you an idea of what I achieve with these mods, here are some pictures I took prior to the snowfall this past year. My driveway is about 500 ft long and lined with bushes and trees. To keep the snowplow from running astray I edge it with reflectors paced out every 30 ft. About 250 ft from where the car is stopped, the driveway drifts left and descends down a slope. The very last dot in the bottom photo - low and centered in the image - is at about 350 ft away. The car is sitting with a set of markers to the left and right around the front doors, so the first markers visible are around 25 ft away.
1 - 20 of 22 Posts
