So I was having cold start issues and a burning smell after changing the timing belt, and SubyTechJoe kindly pointed out I may have the timing slightly out (see http://www.subaruoutback.org/forums...-belt-now-cold-starting-issue.html#post508648).
I checked it and it looked like the driver's side cam mark was half a tooth to the left of the notch on the timing cover. I started again and now have the belt back on and tensioner pin released and wanted to check in here as to whether this looks right (see photo). The belt mark is slightly to the right of the notch in the case and the mark on the cam sprocket is a fraction to the left of the notch. BTW, in this photo the crank mark is bang on the casing mark and the passenger's side camshaft mark is lined up with the casing line.
I counted teeth and there's 43.5 on the driver's side between the crank mark and the cam mark, and 47 on the passenger's side between the crank and the cam mark.
Just wanted to check if this looks good before I put it all back together.
Cheers
Simon
Cheers
Simon
