1 - 11 of 11 Posts
2008 Outback wagon, 2.5i Touring
outback 2008 with basic sound system
are they 5.25, 6.25 6.5 etc
front and rear doors
thank you
Discussion Starter #2
nobody knows ?
2001 OBW VDC, 2004 WRX, 1999 LEGACY L (in a heap)
For every stereo option available, the drivers in the doors are sized 6.5" front and rear.
thank you !
For questions about what fits/works in your car for audio equipment a good source is www.crutchfield.com
and crutchfield tell you that they don't fit in the rear door
is only 1 single bolt hole doesn't align properly crutchfield tell you they don't fit
I will know later this week
Discussion Starter #8
I did the front doors
they need spacers which are not include the windows will rub on them I will fix that later and put the rear ones too at the same times
they sound way better than the OEM
assume spacers are needed for almost all speaker applications in a 90s, 00s Subaru.
Discussion Starter #10
yes learned the hard way
and spacers that fit with these JBL are non-existant so far I had to use regular spacer and cut 1/4 inch all around the inside
2018 Subaru Crosstrek Limited w/Eyesight
I have JBL 6 3/4 speakers installed in all 4 doors of my 2008 Outback. I used the flat metal spacers that came with the speakers, I did not use the angled plastic ones that Crutchfield sent. The space is not perfect for 6 1/2 or 6 3/4, but you can make either work.
1 - 11 of 11 Posts
