How long do you guys go before changing out radiator hoses? I did flush the coolant myself at 40K and now I see a slight drip from the bottom hose at 63K. I was thinking of dumping the cooant again at 65K just because it s cheap and easy insurance. Maybe I should change out the hoses too being that the bottom one is leaking a bit? Or should I just clean and re apply hose during the fluid change?
Do you use a NAPA brand hose or is OEM that much better?
