1 - 2 of 2 Posts
Hi all! I’m hoping someone would be able to give me some tips/clarification on an issue I noticed with my vehicle.
So my 2006 Impreza Outback had a wheel bearing replaced last week. I’ve noticed since then that every time my car goes over a bump around what I estimate is the 25-40mph range, I hear a faint metallic jingle/rattle. I’ve looked up some stuff on what it could be, but I’m curious if anyone had experienced this before or knew off the bat what it was. The wheel bearing was kind of expensive so I just want an idea of what I am dealing with and if it needs another repair. Thanks in advance!
I'd take it back to whoever did the repair - it sounds like maybe they failed to tighten something. Check your lug nuts to make sure none of them are loose - just because that's something easy to check, not that I think it's causing your noise. Can also self-check strut tower bolts if it was a front wheel bearing.
1 - 2 of 2 Posts
