2008 Outback 2.5i, Auto
Hi all,
(First post on here, tried to make sure no one else posted this)
New Outback owner (2008, 2.5, Auto). We really love our new car.
One problem: a previous owner swapped the standard audio input for a 30-pin connector. I want to swap it back to the original 3.5mm jack. Is this something I could/should undertake myself? And where would I start?
Thank you!!
2017 Outback 3.6 Touring, which replaced '05 Outback XT
It should be easy to do if you've done much soldering. Post of photo of what you've got now, so we can understand how it's been modified.
Hi Radar,
Great! Here are some pics of the modified cable, and some wires I was suspecting are the old audio inputs (but I'm not sure). I've done some soldering (enough to fix the airbag light issue a couple months ago).
--Thanks!!
Fresh Out of Outbacks!
Yep looks like they just spliced the lines from the original connector onto the analog output lines from the 30-pin. They wouldn't have needed to adapt signal levels or anything, just a simple splice to result in a different type of connector.
Should be little to it apart from getting the console up for access.
