I have an 07 Outback 2.5i, and I am getting a hum from the rear passenger brake area every time I press the brakes, even at very slow speeds. This does not sound like a break pad warn low sound. I pulled the wheel, and the exposed pad looks ok, and has some meat left so I think it's the caliper, but when I called to dealership they say they have not ordered a single one yet!!! What do others think? Has anyone had issues w/ there calipers? Thanks in advance for any help.
2009 2.5i, H4, Auto.
Did you check both the outside and inside pad? A stuck caliper could cause uneven ware between the two pads.
could also be some debris stuck behind the dust shield. I've had that happen decades ago on a car I owned. It only squealed going backwards for some reason, it was a pebble.
Fresh Out of Outbacks!
The slide pins do get hung up sometimes, but it's not too hard to recondition them so almost nobody replaces the calipers.
Just to toss it out there... wheel bearing?
