1 - 8 of 8 Posts
2010 Outback 2.5i Ltd.
I have a 2002 Outback L.L. Bean Edition. I know there are cargo nets available but how do you hook it up? I had a 1998 Outback before and there were T hooks for the nets but I don't see anything in the current one? Any help will be appreciated. Thank you.:29:
03 H6 OBW & 06 WRX Sportwagon
check ebay - I got one for my WRX there.
Also, try subarugenuineparts.com , if you can't find them under accessories, email Jamie through their system. She has helped me before on an odd part for our 03 OBW.
I know where to get one I'm just trying to figure out where it goes and what it hooks up too and if one can be put into a L.L. Bean? Thank you.
hmmm..mine came with instrucions.
I THINK Jamie might be able to put up a copy of the installation instructions for you. email her thru the site I linked.
probably someone will be along with pics. or try a Google image search - I saw several pics there.
On my WRX, I have one net and it stretches across the back, just inside the hatch. It has hooks at each corner, the ones at the top go into plastic rings on webbing 'tabs' I had to screw in place.
Problem with mine is I don't see where it hooks up to? As I said before my 1998 Outback had some T hooks that the net hooked up to but there is nothing like that in mine and no mention of it in the owners manual either but Subaru lists nets for the 2002 model so I was wondering if the L.L. Bean Edition is excluding from having one? Thanks
2012 2.5i Premium 6MT
With the more recent generation of Outbacks, you actually need to drill a hole and install an anchor bolt/hook of some sort to install the rear cargo net. Not sure if that's the case with your 2002, but I'm guessing it may be - in which case, you won't find any pre-installed anchor points.
2016 Tungsten Outback 3.6R w/Eyesight. My 6th Subaru.
If the 2002 did not come with the net, you had to install the hooks yourself. They came with the net.
1 - 8 of 8 Posts
