1 - 19 of 19 Posts
'01 Outback Apocalypse Wagon, 2.5 5spd
Both of my front lower control arm rear bushings were split and leaking oil, so I purchased brand new parts from the dealer and worked on installing them over the weekend, using the procedure in the factory service manual.
The driver's side went on without a problem, and I was able to get the proper bushing clearance (1 mm at the front, 1.5 mm at the rear) after fiddling with it for a bit.
On the passenger side however, I can't get the proper bushing clearance. With the bushing slid all the way to the front, there is still 2mm clearance at the front, and the washer is up against the spacer at the rear.
I see no indications that the control arm suffered from an impact; everything looks straight.
I tightened everything in the order given in the FSM, with the front tires on ramps so I can fit under the car. The tires are "settled" into the ramps, so there shouldn't be any longitudinal load on the control arm.
Any advice?
Currently in the middle of this job as well, would love to know!
Gonna have to search around for that FSM excerpt... hmmmm
Bump! Anyone have some insight on this?
2010 OBW limited 2.5 CVT
There could be some load with the car on ramps. Try putting the rear of the car up on jack stands to level it out. There could also be some pothole damage too small to see, as well. As small as the difference is, you may be as good as your going to get.
You are referring to the rear front control arm bushing?
Gravy. It works better if you are on a drive on lift. An alignment rack works because you have the benefit of the wheel plates that when the pins are removed, it helps to settle the suspension. After you swap the bushings onto the arms, all the spacers are in the proper place, do not tighten them, only snug the nut so you can still roll the assembly on the arm and leave the frame bolts loose enough for the assembly to move. Set the car down and jounce it a couple times to settle the suspension. Then torque the nut onto the arm and then mounting bolts to the frame. In this fashion, the bushing is set for the suspension without extra load. It also makes up for other worn parts that may be on the car. Also makes up for the settlement of the springs over time.
When you have it done, realign the car.
I've never measured it. Replace the parts, realign the car. There will always be a caster difference in the front wheels, but not enough that will cause a pull or effect steering. In fact, the caster angle is barely off from new. And the cars always handle properly when I've finished.
Don't overthink it. You are making it more difficult than is necessary.
03 H6 OBW & 06 WRX Sportwagon
although I wasn't installing factory mounts, I pretty much did what cardoc described.
(I also learned that I wouldn't bother with changing them just because they lost their fluid. But that's a different rant. lol!)
have you inspected the inner bushing and balljoint? maybe bad on that side.
I used an aftermarket control arm (Dorman) and my gaps are way off, but it tightens just fine.
I believe the torque spec is 137ft-lbs. If the torque is right, then it would make no sense to adjust anything in order to achieve a tighter gap between the bushing and the washers, because the torque would be incorrect then. (I think...)
Discussion Starter #9
Torquing that bushing does not affect the clearance. That nut is supposed to be torqued before setting the clearance. In fact, the FSM says to torque the rear bushing nut with the control arm off the car, though you can only do that if you have the angle marked so that the bushing ends up with no preload when at ride height.
I am following the Subaru factory service manual.
I hope you don't feel like Subaru is overthinking their engineering and the way they build your car!
How can the gap be set at all? Tightening the bushing would theoretically push it against the control arm as far as it goes, right? I don't see how there is any adjustment on this bushing as far as where it sits on the control arm stud.
I'd like to do it right as well, even though I'm sure it isn't that critical. Something about shelling out $85 per bushing makes me want to get it right!
Discussion Starter #11
The slotted adjustment holes in the outer bracket allow you to slide the outer part of the bushing forward and aft. What's actually being done in this step is setting the thrust preload on the bushing.
Does that make sense? You aren't sliding the inner part of the bushing along the control arm, but rather setting the outer part of the bushing in the right place relative to the inner.
I didn't engineer this bushing, but I suspect that setting the thrust preload incorrectly will lead to premature failure of the "sidewalls" of the bushing (imagining it as a tire).
The bolts are to be tightened with the weight of the car on the wheels. The arm will move back and forth through the bushing even after it is torqued, not much, just the total of the "space" left after torquing the nut. The nut stops at the end of the threaded portion, leaving the space fore and aft. It is not meant to be a permanent position of the bushing on the arm since the arm moves with the torque of the drivetrain and jouncing. So, if you follow what I posted, it will be correct. Downside is, it won't work proper if the rear wheels are on the ground and the front on ramps. The weight will be shifted. It has to be level weight. The spacing after everything is tightened is also dependent on whether or not you have other worn parts, such as ball joint, weak springs, strut mount, crossmember bushings or front bushing. It would also be dependent on factors such as bent body or crossmember.
Did you think of any of these other possibilities? Most likely not. So, keep it simple. Get it mounted and realign the car. Don't waste time measuring the bushing position. Its useless on a car with aged parts.
Whenever I explain something, I intend to make it as simple to understand as possible. If I got really technical in explaining every detail, it would make for long post and confused readers. If someone wants technical detail, then I can provide it, but its been my experience that most people don't really understand the mathematics, physics or chemistry involved so I find a simple route.
I apologize if you misunderstood my post. I assumed it was straight forward instruction you needed to finish the job.
Discussion Starter #13
That is incorrect. The nut stops against the inner sleeve of the control arm bushing. It serves to retain the fore-to-aft movement of the inner sleeve as well as prevent the inner sleeve from moving against the control arm.
The control can still move fore and aft when the nut is tight because the inner sleeve is not fully constrained axially to the outer sleeve. Like any bonded rubber bushing, the center sleeve is not (and cannot be) fully constrained axially. Since the inner sleeve is bonded to the outer sleeve through the rubber, it can move against the outer sleeve by deflecting the rubber.
The free-foating castellated thrust bushings serve as progressive stops for the axial motion, and limit toe change under acceleration and braking.
The bushing clearance is adjustable to ensure that there is no thrust preload between the inner and outer sleeves, which might allow the bushing to become overloaded when it reaches the far limit of its fore to aft motion.
Discussion Starter #14
cardoc, I understand you have good intentions in your advice, and from a mechanic's point of view it is probably quite sound. However, from an engineering perspective (mine), it's not totally correct and can lead to problems down the road. Since I keep cars for a long time, and use them very, very, very hard, I prefer to keep things as the engineers of the equipment intended, or modify things based on my own re-engineering where improvements are necessary.
With high mileage, the only way it will be perfect is to change all associated parts on the vehicle. This will be costly.
As an example, my car, which got new rear bushings, gets driven hard. I didn't build it to go fast for nothing. Been driving fast since I was 8. Thank you speed carts. There is no performance change in the suspension now vs replacing all the parts at once.
No offense to engineers in general, but engineers design cars, the technicians have to deal with the aftermath. Most times it is the technicians dealing with engineering faults that come up with the "fix" for what the engineers created. I have an advantage over a lot of techs in that I understand the engineering design and know how each part functions as an assembly and what needs to be done in aspect of either repairing the problem at hand or putting it back to "new". It all depends greatly on what's in your wallet.
I couldn't fault anyone for following the FSM, but, the procedure cardoc outlined should allow the mount to assume a neutral position when the car is in a neutral 'stance'. Even his advice about the use of level ground instead of ramps is aimed at assuring the forces on the mounts are minimal. I did not use OEM when I changed mine, but the prothane instructions were almost identical to cardoc's.
I doubt it would be possible to detect a meaningful difference from either approach, but you have to do what you're comfortable with.
That's what I think is going on. He is working on the arms with the car on jack stands or ramps and its skewing everything. The Subaru guidelines state the wheels need to have the weight of the vehicle on them before torquing the nut and bolts and this cannot be accomplished on stands or ramps as the wheel assembly will move toward the front of the vehicle when the weight of the car shifts to the rear. Physics.
yeah, after dropping the car and bouncing it a few times (maybe I should have rolled it forward and back 4-5 feet - dunno about that) I squeezed my gut under the car with it flat on the garage floor to final torque the bolts.
Discussion Starter #19
I checked it again with all 4 wheels on the ground after going for a drive (with everything tight of course) and the clearance is no different. However, I did check more carefully and found that the aft clearance on the outside is a good deal less (> 1mm) than the inside.
It's likely that the control arm or crossmember is ever so slightly tweaked. You're right, going to need some more parts. I put a control arm on my list of parts for my next order from the dealer. I'll have to look closer for deformation of the crossmember where the front control arm bushing bolts in.
Something probably got bent gradually lap after lap at the last RallyCross Enduro; I do remember now a certain corner that was pretty rough on the pass side.
You are correct that the nuts and bolts fastening the inner sleeves of the bushings need to be torqued with the suspension settled to normal ride height. This is to avoid torsional pre-load of the rubber bushings.
Your comment that the wheel assembly will move toward the front of the vehicle when the weight shifts to the rear is not totally correct if you're careful about it ;).
It's actually the BODY that will move, and in this case that's an important distinction even though the relative motion would be the same. I ensured that the body motion did not impart a thrust load on the front wheel assembly by locking the rear wheels with the parking brake (and chocking them tightly), so the rearward displacement of the body is limited by the rear suspension's limit of deflection. I jostled the chassis on the ramps until it settled on the rear in this fashion. This way there is minimal thrust load on the front wheel assembly, so I could measure the thrust clearance with the front elevated. The fact that this worked is evident by my thrust clearance measurements this evening with the vehicle on the ground being the same as with the configuration I measured them as described above.
Physics! :29:
1 - 19 of 19 Posts
