1 - 2 of 2 Posts
I have a 2002 suburu impreza outback sport. I bought the 5 year extended warranty. Two days ago the back rear hatchback support hing broke, so now the back rear hatchback door will not stay open, as it has only one support lever holding it up. The bolt fell off of the hatchback door, without any unusual wear and tear (just normal opening and closing of the hatchback door)
Has anyone else had this problem? Shouldn't this be included in the warranty?
2004 Legacy Outback
Hey Kati...
Are you referring to the lift mechanism rod or the bolt itself. If the bolt fell out then it should just need to be reinstalled and tightened. As far as I know though, something like that is not a common occurrence.
I would think either way it would be covered under warranty but you would have to check the fine print.
1 - 2 of 2 Posts
