rear jacking point
13450 11
The service manual states that it's ok to use the rear diff. as a center jacking point. I would assume they wouldn't say it unless it's fine. But, I'm a little hesitant. In reality, I'm new to Subaru, and I'm completely ignorant of the strength of the rear diff. Does anyone think there's any problem using the rear diff. as a jacking point?
1 - 12 of 12 Posts
2004 Outback Wagon EJ259 - 4EAT
Go for it. If it was even remotely a bad idea -- the service manual wouldn't recommend it. Think of all the things that aren't recommended but are done anyway, with no ill consequence.
Don't worry about it.
Wow, good info. This will make tire rotation much easier now!!!!
2018 Outback Touring 3.6
If I jack up the back using a center point, won't both back wheels be off the ground? Since the tire rotation is back to front, how will this make the tire rotation easier? I'd like a jack point that puts the both wheels on one side off the ground at the same time.
Depends on your method/tools.<O:p</O:p
Slip a jackstand under the L or R, then move the jack to Fr lift point.<O:p</O:p
The Contis can also be rotated L/R, they’re symmetrical (although I don’t bother L/R). I have 2 floorjacks, so I just lift L/R.<O:p</O:p
And please use only a floorjack to lift the diff.<O:p</O:p
I thought it was back to front, then swap left/right on one end (front or rear).
1 - 12 of 12 Posts
