Can anyone help with the location of the rear running light connector that would be near the rear of the car? I have a fuse (well two) that blow out every so often.. I put a resettable fuse in (power seat type) just so I had lights that would come back on ( cuz it is hard to tell if they aren't working "while driving".. and of course that was bound to fail.. ) So a year and a few dirt roads later they no longer work.. So I plan on a bypass if I can find that connector and disconnect that wire from it. (dead short) I could just run a new one from the relay.. I'll probably need to disconnect it from the front also some how.. If I want to use that oem fuse.. Otherwise I could tie into the front they don't seem to have this issue.. I am usually fairly good at reading wiring schematics but I can't seem to wrap my head around the one I have seen and can't seem to find the location's for the connects either.. I would truly appreciate any help, anyone could offer.. Thanks... 2001 outback
