1 - 2 of 2 Posts
'13 2.5 Premium
After a little more than 60k miles, I noticed the passenger side rear strut on my '13 is leaking oil. It's enough that there is a wet spot on my garage floor, so it's more than simply seeping around a seal.
Anyone else replaced these yet? I'm probably not going to DIY, and will probably replace both at the same time, but I'm also trying to get ready for sticker shock.
Hi,
I see you posed your question a few months ago however, I'm having my rear struts replaced this month. I don't have any leaking but the rear end is very mushy and with all the roundabouts in my area I want to have a better ride. I'm going with the Rallitek/Bilstein B6, Overload spring set up. $699 I'm looking forward to a stiffer ride horizontally but not necessarily vertically. Next Spring I plan on upgrading the end links, sway bar, and some more.
How did your upgrade know? You should definitely replace both at the same time.
4thSubie
1 - 2 of 2 Posts
