Recently purchased a new stereo for my 2003 Outback Limited.
Everything seems to work perfectly, all speakers working, unit switches off with ignition, aerial is attached, but the unit does not pick up any stations ?
Am I missing something ? Is there some sort of booster in the setup I need to attach ?
^Yep. There's a green wire in the wiring harness that goes to the antenna amplifier. It's probably blue for your aftermarket stereo though. Hope you used a wiring harness adapter. It makes life alot easier.
