Replacement fog lights - working after modifying circuit
I just replaced the fog lights in my 2000 OBW with some OEM replacements I bought off amazon. They lit up and blinked a few times but the light on the switch was intermittent. I was lucky to get a picture of them lit last night, but they didn't light this morning at all.
The fogs haven't been used in several years so I'm first guessing the relay may be misbehaving.
Checking the relay I measured the coil resistance at 100ohm, is this correct? For testing, I could swap with a similar relay in the box, and, run a hot wire from the battery to the upper contact (25) in the fuse box?
