The "dinky" spare in the OB is only 1/2" shorter than the standard tire. It is not a tiny space saver like in an economy car. There is enough height difference to be a problem to the AWD system in prolonged use and high speed use . It also may have trouble surviving out on the trail. But let's not paint the spare as some 13" diameter donut,
You're right! :surprise: [
From
https://tiresize.com/comparison/
Tire Size Comparison Calculator
Size 1 225 / 55 R 17
Size 2 155 / 70 R 17
Size 1 : Size 2
Diameter 26.7" : 25.5", -4.5%
Width 8.9" : 6.1", -31.5%
Sidewall 4.9" : 4.3", -12.2%
Circum. 84" : 80.2", -4.5%
Revs/Mile 754 : 790, +36
They differ in diameter by 1.2", so the difference in radius, which affects ground clearance, is 0.6". Since the spare is much higher pressure it might not squat as much, so 0.5" is probably a good estimate. That's less than I thought.
