Pulled and measured the bulbs. If anyone else is interested:
-- Room light and spots use a "festoon" style cylinder bulb with contacts at both pointed ends, 31mm long x 10mm diam, 8 watts each. The site I ordered LED bulbs from calls this a "3022" bulb.
-- Door step lights are also festoon style but slightly smaller, 29mm long x 8mm diam, 3 watts each. Again "3022" seems like the closest fit.
-- Cargo light is type "912", wedge base, bare glass bulb with wire contacts wrapped around the wedge. 1.4" long by 0.6" diam, 13 watts.
I ordered some LED lamps from superbrightleds.com to try out. If the door step lights fit, they should be about the same brightness, but only 1/3 watt instead of 3 watts each. New dome light should be somewhat brighter than stock, but only 1 watt instead of 8. Cargo light, dimmer than stock, but less than 1 watt instead of 13.
I'll post results when I get the new bulbs.
:7:
-Jeff
:7:
-Jeff
