found the following info on how to program keyless entry remote. would this work with one from ebay. $30,00/free delivery. 2000 subaru legacy.
c/p
8. Program remotes: works on Alpine system.
Unlock all doors, foot on brake, all doors closed. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again.
thanks
stickman161
2017 2.5 Outback Ltd
Many Thanks!
After reading this thread, I bought a used OEM remote on Ebay. I was able to program it on the 1st attempt. Total cost was $27.99. The Subaru dealer wanted $86.95 + tax + $50.00 to program it after making an appointment.
Thanks again
· Premium Member
Thanks again
do some FCC numbers on the back have to be 'matched' to the replacement?
mind sharing which ebay seller you used?
thanx
