2013 Limited 2.5i,SAP,NAV
Just one of those "always wondered" questions ...
If you loose the keyless remote ( on cars that use start/stop button) can a new one be programmed using a code number that is available thru the dealer or does the car have to be towed to a dealer where the new remote is matched to the car ? I hope that makes some sense .
Roger
As I understand it the new remote needs to be programmed to the car.
However, on most models, you can do it yourself. I just replaced the one on my Forester with no problems. Although the newer OB might require the dealer.
Info can be found on cars101
Subaru Keyless Entry, Security Alarm, Immobilizer Key, Remote Start Systems. Most years and models
2010+
2010 Subaru keyless remote operation
I do believe that some locksmiths can replicate your existing key code too, eliminating the need to reprogram.
edit: I just realized you have SAP, I don't think cars101 addresses that. My guess is you will need the dealer to program it.
Thanks for the posts ... I'm a pretty through manual reader , but I'll check it again .
First post for me ...great forum !
R
