TWO! 2002 Subaru Outback 3.0 H6 LL Bean
I have a 2002 OBW H6 with 150k and need to do struts all around. Does this mean the springs need to be replaced as well, or are they usually ok? I got one quote so far from a Subaru shop (not dealer) @ $190 per strut, parts + labor. Sound reasonable? Thanks!
I just replaced the struts in my 2005 OBW with KYB Excel-G's, the struts cost me wholesale about $55 each for the front and less for the back. Of course, you should replace the top strut mounts, especially in the front as they have a bearing in them. Those I had to buy from the dealer for about $90 each for the front and Moog after-market for the rear at about $38 each.
My car has 120,000 miles on it. My front springs were worn a bit where they ride in the perch of the strut (ride in the bottom plate in a contour made to hold the spring in position once decompressed within the strut) - there was a bit of a flattened portion where the round spring riding in the sand and dirt of the perch kind of flattened a bit along one bottom edge of each side, I am sure they are still good for another 120,000 miles, so I opted to NOT replace the springs.
I think the KYB's that I got are a more aggressive strut than OEM, these take bumps and turns a lot better. The OEM's seem to ride like a baby carriage compared to these.
$190 PLUS LABOR is a lot in my mind, however, I have been doing my own repairs on everything anymore, being out of work for so long. I make out better staying home and fixing things than I do working and then paying others to fix things (and half the time they don't get things RIGHT!).:mad:
You may also want to look at your sway bar bushings and end links for front and back. I replaced the front at 60,000 miles and then again at 120,000 miles as they would make a banging type sound with every small bump. I thought something like the struts were loose, come to find out the sway bar bushings were not tight anymore due to all the bumpy roads around here.
Thanks, so it sounds like my springs should be ok. I'm guessing the shop will tell me I need them replaced as well so I figured I'd ask here first. I looked into doing it myself but I don't have a garage and don't want to try and do this out in the parking lot. Plus no air tools if things are really stuck. With 150k, they're probably stuck.
You are wise to not try to start this job in a parking lot. I had mine up on jack stands for a month, however, I was in no hurry at all, the car was in my garage, and we have another vehicle we shared. I did all new struts, all new brakes, new calipers, changed all fluids to synthetic, the whole nine yards.
For how much cars cost today, we surely cannot afford to buy a new one, and with all the work I did on it, I sure hope to get another seven years and 120K (or more) miles out of 'her'!
For $38, I bought an Impact Wrench for a compressor I already owned. You are right, there were some nastily-rusted bolts there that I had to remove and, that wrench, even though made in China, really helped A LOT!
13 E350
50 bucks will get you an electric impact from autozone or harbor freight. I change mine suspension twice a year so i can actually do a whole swap in about 3 hours with just hand tools on a side of the road. 2 hours if i have my floor jack and impact wrench.
