Reverse camera on 2008 Outback
133 Views 2 Replies 3 Participants Last post by  Toad442
Hey, I have a 2008 Outback 3.0, JDM, RHD. Owned since 2019.
This particular car has OEM xenon headlights, reversing camera, flappy paddle shifters, stereo with a HDD, multi-function touch screen display with japanese sat-nav, japanese TV tuner etc. Most of this you don't see in many 3rd gen outbacks, so I have trouble finding parts and knowledge for it, especially it being JDM. Hoping someone here might be able to help :)
My main problem is the reversing camera stopped working a couple months ago. Now the screen just goes black, with the guide lines moved to the right and down a bit which is kinda strange.
We assumed it was just a faulty camera - I found the part number but cannot source a replacement even from subaru, seems they stopped selling them some time ago.
We took it to a shop that normally installs/fixes this kind of stuff said they had aftermarket cameras that will work, but they plugged in a few different cameras and none of them worked. They said they hadn't seen one with this OEM stereo unit before and it must have been a very high spec model for the time. Unsure if there's anything special about the camera or maybe the head unit that processes the video signal has a fault?
Anyone know what the likely issue is here?
The camera wires may have gotten broken where the hatch opens and closes from the thousands of times it’s opened in it’s life
Reactions: 1
I'm with him.^^^ Probably a busted wire. Can be a cam too.
Gotta old security cam? You can test if the HU is bad or if something beyond it is bad.
Here's the pinout chart.
Runs on NTSC logic. I don't think you have much NTSC logic stuff on your side of the pond.
If you want to run an aftermarket HU on a factory cam or a aftermarket cam on a factory HU, you need what is called a Retention Harness.
