Hello -
When I install new rear LCAs on my Outback, should I torque the control arm nut once the car is sitting on the ground, or does the LCA spin freely in the bushing once torqued?
Mine just started leaking immediately after lifting the car 1", and I'm wondering if the new ride height stretched the bushing in a way that it usually isn't supposed to be stretched. "Out of it's range," so to speak.
I'm considering going with these:
4 Front Lower Control Arm Bushing Subaru Outback 00 04 Baja 03 06 | eBay
The price is definitely right. Considering I can't find anything other than OEM right now, (and I don't want to go poly) this is my first choice. Is this a good route, has anyone used these aftermarket bushings? Or, where is the cheapest OEM vendor to get the genuine Subaru fluid filled bushings?
Thanks!
