The drivers side seat seat warmer in my 05 OB seems to have lost its ability to shut off when set to the minimum heat position. it just keeps getting hot to the point of feeling like a hazard. Any ideas where I should start looking for the problem?
The 05's have more positions in the heat warmer switch than the newer "Low-High" switch. Mine seems to go up to bun-burning temperature when set to the lowest position... which it has never done before.As far as I know (at least on 13 OB) the heat is on until you manually switch it off. I may be wrong or the 05 OBs have a different set up.
