Sounds like either brake dust or 'industrial fallout' - airborne metal shavings that embed in the paint and then start oxidizing. AFAIK the quick DIY solution is to use a clay bar on the paint: wash, use clay on the whole surface, rubbing in the same direction as air passes over each part, then finish up with at least a wax if not more. The article below has a good set of pictures and instructions.
