1 - 19 of 19 Posts
2018 2.5i Premium - No Eyesight (and proud of it)
Scangauge II / Xgauge Questions and answers
Are there codes available to get Engine Oil Temp and/or Engine Oil Pressure ?
2017 Outback Premium 2.5 with Eyesight. 19mm Rear Sway Bar. Steering Dampener Lock Down. HID upgrade from retrofit source.
There are no special codes that I know of for engine oil temp or pressure. I think the pressure sensor is also either showing pressure or not, I'm not sure there is a discernible value. Oil temp on my 2.5 generally runs 10-20 degrees warmer than the coolant. I just show water temp on the scangauge.
2012 Outback 3.6R
How are you determining the oil temperature?
Infotainment system. Info screen. Vehicle monitor.
Got It, thanks
2016 Tungsten Outback 2.5l Premium w/ES, OP 14, PP #4
Check post #41. https://www.subaruoutback.org/forums/138-gen-5-2015-2019/462985-cvt-cold-weather-issues-5.html @Brucey posted this info awhile back. My Scangauge has ver. 3.17 firmware and the passive values in the table work for several parameters including CVT fluid temps. Engine oil temps agree with those displayed on the info. screen. Haven't found any oil pressure PID's
Thanks for the tip, however, I tried the codes for the Passive Oil Temp and they did not work for me. It may be due to my model year. I am running 4.5 firmware.
I can get my Oil Temp from the on-board management system but was just wanting it to display with my others on the Scangauge.
I am getting CVT temp - I got those codes off the Scangauge web site.
Discussion Starter #9
@p12 there's a couple more engine oil temperatures listed down the page. Might try them.
Thank you, I didn't notice that.
I got the second one listed to work. It's nice having these together : Oil temp, CVT temp, Water temp, Voltage
Thanks again. :smile2:
Brucey
'17 3.6 Limited
Can you list the code that worked for you?
2017 2.5i Premium Lapis Blue
I picked up another Scangauge II today to put in my GMC Sierra. AutoZone has a sale on it until March 4 for $40 off. Their regular price is $159.99 and that is what Amazon currently shows as well. The Scangauge website shows it for $169.99. With the discount at AutoZone it was $119.99. Still a little spendy but a pretty good deal for anyone thinking about it.
https://www.autozone.com/accessories/_/N-26p9?itemIdentifier=914192_0_0&showDeal=true&skuAvl[email protected]636acc56&skuId=914192
The pic below is just a screenshot so there aren't any working links in it.
2008 Outback 2.5
$160 Ouch.
I have an UltraGague. It cost $80 and displays 7 pages of up to 8 values per page.
However, I lent it to my son who is still using it and have now been using a $20 wifi OBD2 adapter and a $4 iPhone App called "Car Scanner". The free version is fully functional for something like a month, then it's limited to the types of info it will display but for $4 for the fully functional version, it's great.
It's a display freak's dream. You can display virtually any OBD parameter as well as calculated parameters like estimated instantaneous horsepower based on fuel consumption. You can display numerical values, an "analog gauge" or a graph and change colors, font sizes, redlines, alarms, even make it mirrored to act as a HUD.
I don't use my current iPhone (Xr) for the display, I use an old iPhone 5s or SE. Makes great use of something that would otherwise sit on a shelf collecting dust.
There are also Apps for Android and you can use an even cheaper (<$10) ELM327 based Bluetooth adapter with Android phones.
2017 Outback Premium (no eyesight) 48K miles
This is what the folks at scan gauge have listed on the site for gen 5 outbacks Xgauge:
CVT Fluid Temperature (°F)
Actual Gear Ratio
Target Gear Ratio
Secondary Pulley Speed
Primary Pulley Speed
Lock Up Duty Ratio
Transfer Duty Ratio
Turbine Revolution Speed
The forester have about 4 or 5X the number of commands listed for that vehicle.
These are the other two Oil commands in the PDF, I haven't had a chance to try them.
Oops, somehow missed the post where he gave the command, its the second one in my jpeg.
Actual Gear Ratio
Target Gear Ratio
Lock Up Duty Ratio
Transfer Duty Ratio
I don't remember seeing the actual and target gear ratio Xgauges before.
The firmware in my original Scangauge was too old for some of those to work and I can't remember if I tried all of them when got my second one. I know I have horsepower as well but that might be one of the standard ones that isn't vehicle specific. I always have engine oil temp and CVT temp displayed as well.
I found an engine torque Xgauge for my 2010 GMC but it didn't work so hopefully I just entered a number wrong. I haven't had a chance to look at it any more.
2016 Outback Limited 3.6R: The first code string for engine oil temperature “07DF015C” worked. Thank you very much! Matches the temp on the vehicle monitoring screen exactly.
2016 Limited Outback 3.6R, for engine oil temperature.
Engine Oil Temperature Codes, in order of entry when programming, for the ScanGauge II, XGauge. "07DF015C 0441055C0000 2808 00090005FFD8 OTF"
$160 Ouch.
What is the $20 OBD2 adapter that you are using for iPhone. I would like to get a set up so I can better accurately monitor the car's diagnostics and coolant temp. Will it show real time data?
2008 Outback 2.5
Sorry for the late reply. The Wifi OBD2 adapter looks like this one
It puts out a big bright light show with all the LED's flashing so it's pretty distracting and sticks down towards you feet. So I bought an extension cable:
and tuck the cable and dongle up under the dash so I don't see the light show or bump the dongle while driving.
The dongle draws power even when the engine is off so if I am going on a vacation and not driving the car for a while, I'll unplug the dongle and put it in the house but leave the cable plugged in so I don't wear out the OBD2 connection.
1 - 19 of 19 Posts
