1999 Legacy OBW
I'm trying to make sure I understand this right. You insert a screwdriver into the port on the rear of the engine and hold the flywheel which stops the crank from turning. Can you insert the screwdriver into the flex plate to achieve the same results? I've got an ej25 that I'm working on but it's not in the car so there is no flywheel attached.
