2020 Limted XT Black/Ivory
I need to pull the front seat to do some work. Does anyone have access to the torque specs for the seat bolts?
2010 2.5 CVT Limited
Be aware, when you disconnect the occupant sensors and airbag connections from the seat, you may need the BCM reset with a scan tool. That was the case for a friend's older Toyota. I don't see a newer car being less complicated.
Awesome, thanks. I think the Outback is self testing so as long as it’s hooked up when it does its diagnostic test on startup, it should be fine. If not, clearing it won’t be an issue.
