Merry Christmas, Happy Chanukah, Habari Gani (Kwanzaa) and best wishes for the New Year to you and your families!
Started our 2003 Outback VDC 3L H6 111K miles, and shifter was locked - stepped on brakes and couldn't shift shifter back to Drive after shifting to the right from Park. And every time I moved the shifter to the right from Park, I heard a click from the steering column - my guess is that's a solenoid in the steering column that controls the shift lock.
Then I checked the brake lights - not working when the brakes are depressed. I think the brake lights and shift lock are likely on the same fuse. What do you think - most likely cause is blown fuse?
Hoping that the Shift Lock Release with a screwdriver works so I can drive the car to the garage - any tips on engaging the Shift Lock Release? Looks pretty simple.
