561 - 576 of 576 Posts
2020 Outback XT Touring
For those interested in USB cables for the center console, I bought these Aukey right angle cables. I got the 3' Lightning cables. They also come in USB C flavor.
My review: When plugged into the USB A in the car (the white block in the USB A is on top), the cord will point to the right. I'm fine with this, but didn't see anyone else specify that information.
The lightning plus is also right angle, which I thought would be good, but what I've found is that when holding the phone, I'm used to the cord going straight down. When the cord goes off to one side, it interferes with my pinky finger which is balancing the phone. So it's really awkward to hole the phone now. Also, it seems to make the lightning plus wiggle left to right, which worries me about damaging my port over time. That said, the cable build quality seems good, and it includes a velcro strap to wrap up excess cord. 3' is plenty for front seat use, and i have most of it wrapped up anyway. Don't know if I'd go shorter, just so I can bring it closer to my body if I want.
I'm going to see if keeping the right angle lightning plus is beneficial when using the ProClip mount (for CarPlay), but if I have enough clearance for a straight lightning plug, I'll likely switch. Here's one I'm considering:
Not sure if this could work for you, but I’ll share my iPhone 11 Pro Max setup. It has an 8-in lightning cable with straight male connectors. This setup works just fine for me. Note that I did cut a small rectangular piece of no-slip pad just because I didn't want it to slide when I made turns. But it really didn’t slip before this mod. The short cable also helps stabilizes it in place. Amazon doesn’t carry these 8 inches anymore it seems.
Onyx
I'm happy with these two cables.
Amazon.com: Oxsubor SuperSpeed USB 3.0 Male to Female Extension Data Cable Left and Right Angle 2PCS (20CM,8IN): Computers & Accessories
Pros
  • Super quick one handed connect/disconnect
  • 1.6' cable is nice in combination with the adapter, I can hand hold phone but not much excess
  • works with CarPlay, usually
  • If you like the magnet approach (I do) it's a convenient way to charge the phone everywhere, not just the car.
Cons
  • Occasionally I get the "car play cannot connect" message and have to unplug, replug.
  • If you're holding your phone it's easy to accidentally disconnect the cable
  • To use a wired headset or regular lightning cable you have to pull out the magnetic plug.
  • Cable has an LED which I don't like in the bedroom - nail polish.
I’m putting my Tuxmats in and I’ve got a question. They cover all over the place but the fit isn’t very tight? That or I’m installing them wrong.
For example, here are a few pics from the backseat. There are “bubbles” along the edge where the Tuxmat doesn’t hug the interior of the car. Is anyone else experiencing this?
Sent from my iPhone using Tapatalk Pro
I bought this same one but havn't gotten around to installing it. Surprisingly, in 6 mos of carring the keys around in my pockets ( pants or jacket), I still havn't accidently acctivated a button. I think the fob is pretty well designed with the flush button design.
I bought one (actually two) to put on my keyfobs. Be prepared to work VERY HARD to get it on the fob! I'm not sure if it'll actually help with the accidentally pushing buttons while in my pocket, but I'll see. I'll still keep my eyes open for some sort of hard case.
They are difficult to get on, but worth the effort IMO. They are initially grabby during/after installation, but a week later, they aren't so tactile. Do let us know if you find something you like better!
There are several that should work on Amazon. The question then becomes how hard is it is to operate the fob once it's installed.
I really don't need much access to the fob buttons themselves. I just need the fob to be close to the car for me to unlock the car and start/operate it. I had looked at the link you showed but it seemed it would be a little large to put in my front pants pocket.
The second looked a little closer but I had one similar for my legacy and, as the leather relaxed, it did not keep the buttons from being accidentally pressed.
I also bought the jacket that you guys are referring to and then bought these ones, recommended on this thread: https://www.amazon.com/gp/product/B071FQ4WF3/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
They do fit the new and newer Outbacks, despite what the Amazon fit guide says. I really like this one!
I just received mine as well and have the same problem, except I couldn’t even get it as snug as yours. I am going to reach out to Tuxmats this week and see what they say.
Front mats fit perfectly. It’s only the back row that seems to have issues.
483794
Mine fit ok. Idk
Out of curiosity, what is the SKU number on your back row Tuxmats? Mine is 546. (It's on a tag attached to the middle area that tucks into the back seats.)
I just received my mats last week, after they had been out of stock for a month or more. I'm wondering if I either got the wrong mats or if there's some variance in the latest manufacturing run.
483805
2020 Outback Touring XT
I just got mine. Perfect fit for the 2020 Outback key fob. Easy install. Good button protection that will hopefully keep the hatch closed when I want it to stay closed - no more surprises in the morning.
Sure wish there were retaining pins for the passenger side OEM all-weather floormats. Such an annoyance keeping them in the correct position.
