581 - 600 of 625 Posts
On my Infiniti there were rain drains installed around the moonroof, and after installing the moonroof deflector they would get clogged with gunk. The genius who designed them decided that when the drains get clogged they would overflow into the passenger area. Yes, really.
i hope such manufacturing idiocy isn't evident in other vehicles, but it may be worth checking.
Thanks, I will keep an eye on it. I know these things can collect allot of junk. (Which is a main reason why I installed it so it can be taken off for occasional cleaning.) That said, the car is garaged and pampered so I hope it doesn't gunk up too quickly.
Question for anyone who has the ProClip console mount.
Can you tell if it is possible to mount it on the driver's side of the console instead of the passenger side?
I know that ProClip offers a vent mounted holder, but I really don't want to block the already tiny vent any further.
Thanks!
2020 Onyx XT Autumn Metallic Green 3/13/20
Thanks!
No. The part that physically clips on to the console and the angled piece the device holder mounts to are fused together and not adjustable or reversible. Also, if it mounted on the driver's side, it would block the parking brake control.
That being said, I am very pleased with the mount.
Thanks for the input as I was not completely sure how it was made.
I guess I'll just keep looking, as would really like to have it mounted so the phone is to the left of the console.
I contacted ProClip as well since I have heard such good things about them, but they stated that they have no plans on making one for the driver's side.
485247
2020 Outback Onyx XT in Autumn Green Metallic
I can see how reaching it would be easier, but that position would be in the way of me resting my leg when using cruise control. Honestly, as is, I still wouldn't mind an extra inch.
2020 Limited XT Autumn Green Metallic/Warm Ivory, Falken WIldpeak A/T Trail, OEM Skid Plates etc
Small update :)
2019 Touring (Canadian Model) with Eyesight
The mount I have will fit your case guaranteed. It's not as clean as the proclip, but if you install it with care and attention, it will position the phone in the same place that the proclip will, and it's a bargain.
In normal use, the passenger will not make contact with the support rod, nor will it be noticed - I pushed the seat far back to show the mount, but it's normally forward of this position and the mounting bolt is not showing.
I've been thinking about whether it would be possible to use the ProClip in conjunction with my current phone holder, or another "squeeze to fit" type holder, but not pulling the trigger on the ProClip until I figure that out.
Just saw this post while searching for something else, but I made something like this mount from scratch. I used a gooseneck lamp and a piece of metal to mount to the bolt of the passenger seat. Although I did this on a matrix, it should be doable on the Outback
2020 Limited XT, Abyss Blue Pearl
I always liked these, and had a different mount from this company on the seatback of our '14 OB so that our daughter could mount her iPad mini. The issue I have with these gooseneck mounts is that they are too low - force your eyes DOWN off the road if using for navigation. I want something to replicate a HUD at eye level, which is why I usually go with magnetic mounts more or less at eye level. Even the CarPlay integration in our 11" screen is too low for my liking, but I'll get used to it.
I recently (last week) got a limited XT. Compared to my last couple of vehicles, I was not very happy with the sound quality of the stereo system.
I read in another area of the site about putting something over the center speaker in the dashboard to improve the sound.
Today, I put one of those thin, sticky gel pads, made for holding a phone or glasses in place, over the speaker. It made a noticeable improvement.
I think I paid all of $3 for it at a store a couple of years ago, but they are still fairly cheap on Amazon or at a dollar store.
I think it is well with trying. The sound is filter and the separation is improved.
Yes, I found a marked improvement myself.
Does anyone know of a hard key fob case? I would like something that will keep the buttons from being accidentally pressed while in my pocket. Ideally, the fob would be completely covered but be able to extend out for use. Sort of like the blade of a knife. I had a cover for my Legacy fob but it really wasn't rigid enough. Obviously, it would still have to be small enough to carry in my pocket.
So I tried the soft cases sugessted but The keyfoc button woul dstill depress when in my pocket. I finally found a small pill case on Amazon that fit the keyfob perfectly. I'm not 100% satisfied because the hinges and latch are a little large but the entire thing fits in my pocket. I was looking for a mint tin like Altoidsthat would work but the regular size was too big and the small size too small. As it turns out the small size fit my garage door opener fob perfectly.
Now the buttons of both fobs don't get accidentally depressed.
The case I got was https://www.amazon.com/gp/product/B078MVX8G7/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1. I cut out the small pill divider slots and cut a small slit for the keyring to go through. I still fits in my pocket pretty well.
487074
487075
2020 Outback Touring XT
I have this to put over my seat when I get done either running or cycling.
I just ordered the neoprene console cover. I'm waiting on it to come in and then I can take some pictures.
I used to have pro clip but in this car I didnt like how it would work, so I went with another option that I am very happy with.
Involves the magnet on the back of the phone but... it sits right where I want it - which is sort of what you mean. It sits just on the upper part of the vent - not really blocking it at all, if you put the magnet in the right place on the phone so it sits higher. Im someone who does NOT want to block the vent, and this just bleeds into the top space of it but not enough to notice any difference. Look at all 4 car photos in my post here (not counting the product photos)
2020 Subaru Outback Onyx XT
Finally got all of my stuff in. The wife and I decided to take the car out for a long drive just as the San Gabriel Mountains in SoCal got a nice dusting of snow. I was extremely impressed with how the OB handled the weather! Then next day it was sunny and warm Spent all day with a full detail and installing some of my new goodies. Installed the Yakima Load warrior, emblem overlays, smoked side marker and yellow fog light vinyl overlays. Loving it so far!
View attachment 482282 View attachment 482283 View attachment 482284 View attachment 482285 View attachment 482286
Nice. Curious: are the yellow fog lights from Crux Motorsports? Just ordered a pair but wondering about the install and whether you had to remove the entire bumper or just right on with a heat gun?
I did not have to remove anything to install mine.
So what guys are you using for the gap between the seat and center storage for storage? Been looking at them but don’t know if they’re all created equal.
