1 - 13 of 13 Posts
2002 OBW 2.5L 5MT
Hi,
I am new to the forum. I just got a 2002 outback 5 speed last week. I am thinking of getting a set of snow and mud tires for the wagon. Can you guys tell me want size should I go with as I would like to get a narrower tire....215/65R16? or should I get some steel 15" rims and put some 215/75R15. If I go with the 15" rims would that clear the brakes. Your expert reply would be greatly appreaciate.
Jim
Fresh Out of Outbacks!
A 205/65R16 would be a closer match to stock circumference while going a bit narrower.
205/70R15 is probably the right fit if you want to go to 15". Most 15" tires are a good bit cheaper than larger sizes, maybe enough to pay for the steelies too.
15" steel will clear stock brakes. Use a tire size calculator to verify that you are staying close to the stock circumference, if you haven't already. This will let you compare different tires.
2002 OBW 2.5L 5MT
Thanks for the great info. I'll look for some 15" steelies.:29: Do you think the Forester steel rims would fit the outback?
· Meh.
I has wagons.
They will. BUT, not sure 15" will clear your brakes.
2002 was a transition year for a rotor change. 15 will clear the earlier style, but not the newer.
2002 OBW 2.5L 5MT
Now how do I know which has the newer rotors. My VIN can tell?
· Meh.
I has wagons.
DIY-Turbo 2.2l OBS 12.89s 1/4mile @ 106.17MPH
+1
I can ID the front brakes visually as follows:
If you look @ the swept area of the front disks - the newer/bigger brake have more unswept area then the smaller/older disk set-up.
If you have about .5-.7" of unswept area towards the center of the rotor you have the bigger brakes.
If the pads sweep just about the entire rotor you have the smaller brakes.
Note: Front Brake Calipers & Pads are the same for both the 10.9" & 11.4" front brake rotor set-ups (which is why there is more unswept area on the big brake set-up).
Pics would help but I do no have any handy...
2002 OBW 2.5L 5MT
Discussion Starter · #10 ·
im running 215/70/16 this is the second season on them with no issues
Can you take a pic of the wheels. Just like to see how high the car sit up, as 70's are a lot higher then the 60's in the original tires. Maybe I'll do 205/70 16:D
2002 OBW 2.5L 5MT
Discussion Starter · #11 ·
1 - 13 of 13 Posts
