So I took my OB to the dealer last Wednesday to have the starter replaced. While I was sitting in the waiting room the service manager came up to me and said that they noticed the front right CV boot was leaking grease and flinging it around under the car. I immediately thought about the 1" Subtle lift I installed just a month before. Luckily the dealer covered the repair under warrenty without issue :29:
So fast forward to today, I just got it back after they had to wait for the new starter to show up Monday morning. So after work I was poking around the engine bay to see what was replaced. The passanger side inner CV boot is where the leak was. It looks like they replaced the inner CV boot and cleaned up the surrounding area. However, when I go over to the driver side, just under the new starter that was installed, I'm noticing grease coming from the inner cv boot towards the bottom as well. I'm thinking about calling the dealership back to see if that one needs to be replaced as well :28:
So...I'm wondering if these "leaks" are a direct cause of the 1" lift.
I mean, my OB only has 47k on it, so it seem too early for issues like this. Not to mention, both CV boots seemed fine just a month ago and to have one, maybe two, fail so close together seems fishy...
Now, I did a ton of research before adding the spacers to the Kings and KYBs I had already installed. I know this is a very popular combination and the amount of lift gained seems well within the "save" amount. I mean, the angle for the axles doesn't seem that bad at all just by looking at it. I'm hoping that it's just a case of these boots being bad to begin with and that now one is fixed, that should be the end of it.
