2018 Outback 3.6R Limited; 2" LP Aventure lift, LPA skid plates and small bumper guard, diff breather relocation, subframe skids; Motegi MR118 17x8et32 wheels; Yakima LoadWarrior with extension; ARB
Trying to keep this local for the moment, in the Atlanta, GA area.
Detours Off-road Knucklebone hitch mounted spare tire carrier. Used and in good condition. Bedliner paint job shows some use, but is perfectly functional. I’ve had the bolts (that the wheel mounts on) welded on so replacing the wheel onto the carrier is much easier. Included is the hardware to mount the license plate through the center of the wheel, if one wants (you will need to figure out lighting on your own). This model has the 40 degree stop built in, so the tire lowers only part way, making it easier to get it back up into position to lock.
Asking $350. Located in 30044, and prefer to sell within 2 hours of my location at the most, for the time being.
2014 3.6R Limited
Do those things really cost that much? I look at the attachment for my tractor so I can move trailers around that cost around $100. It's got twice as much metal and welding than that tire carrier! If I want one Fab shop here I come!
They aren't cheap, and lacking the proper tools they're certainly not easy to make. Plenty have done it though, so I wish you luck!
