Hi
On my 2019 OB 5th Gen, I had an issue whenever I tried to stream a podcast or music from my iPhone 12 Pro. There was a lot of static and the voice would break up to the extent it was unusable. I would have to use a cable to connect to the usb port to listen.
I turned the OB's WiFi off and it solved the problem. No more static. When I need to check for a map update I will turn it back on but won't be leaving it on any more.
If one is going for a short drive it was is a hassle to plug iPhone in to listen to.
