I would just leave it until you notice something, Sometimes you wonder if 60K replacement is for the dealers to make money on those who are unable to do the job at home.
When the going dealer cost to replace, I am told, is now about $600 who wants to replace them earlier than needed? If my calculations are correct, evaluating this completely on fuel cost, at $5 a gallon with an average mpg of 30, you would need to improve mpg by 4.5% or 1.35 additional mpg before you would pay for the cost of a $600 spark plug replacement by changing them at 60,000 rather than 80,000. This is without taking into account if you replaced at 60, at 80 you would have plugs that are 1/3 used up. Without figuring any changes in costs then you add another 4.5% or 1.35 mpg to get 9% and 2.7 additional mpg. From fuel savings-only point of view, it looks hard to justify new plugs if you are going to have a dealer do it and you are not experiencing any symptoms of worn plugs.
If you DIY, without considering your time, tools, and frustration cost, then you could break even with a substantially less increase in mpg. The tool cost isn't really that much, because if you have a 3/8 rachet and 3/8 socket set with metric sockets for the battery box and a few other small items that need to be removed, plus a 14mm open-end wrench, which most people do, then all you need is a special plug wrench like this
https://www.amazon.com/gp/product/B08FRH2PYL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 with a 1" extension. I used a 3/8 to 1/4 adapter with a 1/4 back to 3/8 adapter which turned out to be about 1". I got the NGK Ruthenium plugs from Rockauto for $8.55 a piece. Follow the thread here
StickySpark plug DIY? plus look at a few youtube videos and with a little first aid cream, you are all set for a few frustrating hours, but rewarding in knowing you accomplished something a lot of people won't try.
