I changed the air filter, and pulled a plug wire on the right side, unfortunately I found oil on the wire boot.
Car has 70,000 miles, 2008. I have the Gold warranty plan. I would hope this is covered. I'll find out tomorrow when I call the dealer.
Its disappointing it happened in less than 70k miles. Looks like a considerable job. On the right side do you have to remove the timing belt cover to remove the rocker cover? It seems you strip the front to point of doing a timing belt change to get access to the cover fasteners.
Has anyone tested the Gold plan for this?
