1 - 10 of 10 Posts
Does anyone have experience in changing sparkplugs in the 2.5. I was looking at my 02 OBS and it looks like they arepretty hard to get to. Any advice?
2007 outback MT
I just replaced all of mine and it is actually a pretty simple task. For the left side of the engine bay you have to remove the air intake and resinator boxes. Most of this you can pull out without tools, but i think there are 2 bolts to be removed. The right side is a bit tougher. You have to loosen the winsheild washer resivoir. However i was able to replace the plugs without removing the hoses from the resivoir, just make sure the it is at most half full. As far as the spark plugs go a long extension helps alot here. All in all this took about 20 min.
Good luck!
Changed my plugs and had a question. I was kind of concerned about the corrosion on the end of the plugs. Is this normal for Subaru's. Thanks
Superb Moderator, ,
MY12 WRX, MY07 FXT
Corrosion exactly where? I see some on the nut portion of the plugs and that is nothing to worry about. Is there whitish/reddish on the tips of the electrodes? I can't tell by the pics, but everything looks allright to me. Brian
sparkplug change
I am trying to learn the best method, and another site said to approach the task from underneath the car, and avoid removing reservoir, etc. The dealer wants $200 (with plugs costing--get this--$21 apiece). LOL!!!:eek:
core on those plugs made of pure unobtanium, no doubt...:D
Superb Moderator, ,
MY12 WRX, MY07 FXT
tonicfive, what engine do you have and what year? It's not in your profile and you did not tell us. And you can do it easily with removing the plastic intake tubing on one side and unscrewing the washer fluid tank and setting it against the shock tower. No problemo. If it's a four cylinder. Brian
2007 Outback 2.5i
Good luck!
20 minutes and no tools? What are YOU smoking!! Did mine today, it took 2-1/2 hours. A royal PITA, although it was worth it.
Superb Moderator, ,
MY12 WRX, MY07 FXT
Can do mine in less than 20 minutes. Depends if you have your plastic intake plumbing on your passenger side, what tools you have, and how long you don't want to spend hanging over a hot engine. Brian
1 - 10 of 10 Posts
