21 - 40 of 66 Posts
2020 Legacy Limited XT
I talked to my Dealer yesterday about this and he said that if you don't renew the Starlink subscription the MySubaru App is worthless.
My wife only used the app for the remote start function and other than checking for recalls, which I’ve found out about here long before I see it in the app, I didn’t use it for much else. Is there another way to access a remote start function? I’m aware of the separate fob that was/is available, but can that be added and used if it wasn’t included when the vehicle was purchased? It might not be of much use for us since we live in a condo building some distance away from where the cars are parked but I am curious about it. My wife would be interested in that if it were feasible. Other than that, the subscription wouldn’t be worth it. It’s too bad they couldn’t continue the 3 year option for $75-$150. At a max of $50 a year we would consider it. Seems like they would also benefit as opposed to those like us who will just cancel.
The app-based remote start function relies on cellular connectivity to the car. Without a Starlink subscription that connectivity is suspended so there would be no way for the command to reach the vehicle.
Granted, but there is a separate remote start fob. Can that be added? Again it might not be a viable option for us.
Ah, I see that remote start can be performed by the existing key fob. I didn’t know about that. But that still has a distance issue for us. We might try it though and see how far away it can be used.
2023 Outback Touring XT - Deep Mahogany Pearl
My experience is that it works pretty much by "line of sight"! If you can't see or hear the car it doesn't work (or you don't know if it did work)!
2020 Legacy Touring XT
If you get the remote start installed you can use the existing fob but only for short distances. The kit includes a separate remote that is supposed to go to 200' or something like that.
'23 Legacy Touring XT
It can only be done with the existing fob if you get the add-on remote start installed. That will give you a separate fob for long distances (up to 400ft with no obstructions) or you could use the main fob for short distances (50-75ft). This will not work unless you get the add-on remote start installed. Yes, you can get it installed later even if it wasn't included with the purchase. However, it will cost a lot and you're better off with renewing the Starlink subscription.
2020 White Limited Hybrid
I left my car at a friend's house in Portland and flew to Florida for a cruise last April. I called my friend and told him to go out in his driveway.
Using the app, I remote started it from Florida!
There is obviously no distance problem using the app. This year when I go to Asia I'll try the same thing.
Reactions: DanielAcosta
· Premium Member
This.
For the retail cost of buying the remote start and having it installed you pay will $700ish. For that price you can buy 4+ years of Starlink service at $150/year.
As a side note, you can set up Starlink to work with the voice capability of you phone and run the commands via voice.
As long as you have Internet service on your phone you can remote start your car from anywhere in the world! But the discussion here is really remote start via the key FOB - not the App.
Thanks guys, I wasn’t aware of what was necessary for the separate fob or using the existing key fob. Either way renewing the subscription or having the add-on mechanism installed it’s not really worth it to us. We’re still waiting for Subaru to fix the transmission, remote start is a bit superfluous when your car is disabled:mad:
2019 Ascent Touring (me) 2020 Forester Limited (Spouse) 2016 Outback Limited (Daughter)
You can have the fob-based remote start system installed...the parts are likely about $400 and the labor is on top of that. This is only available as a dealer installed accessory...it's not been available "from the factory/port" for years now as they encourage use of the StarLink subscription.
Reactions: Jp1975
Thanks. I asked my wife if she wanted to push for that as some kind of compensation for this transmission ordeal but she’s not interested. Neither the Starlink subscription nor this remote start system is worth it to us at this time.
How do you do that? Curious and thanks
The process is linked to in the comment you quoted...the blue lettering. Click on it. :)
· Premium Member
Based on the last part of his comment I think he watched the video and decided it wasn’t worth the effort. To be fair, it does seem a bit daunting when you first look at it. I had never used Siri Shortcuts before so that was a learning experience.
As an FYI, on mobile (iPhone) the links don’t show up as blue.
21 - 40 of 66 Posts
